1992 Ford Bronco adding fule
1992 FORD BRONCO
203,000 MILES • V8 • 4WD • AUTOMATIC
BRONCO5887
I had the fuel pump replaced on my 92 Ford Bronco last week and now I can't put gas into it. I can maby get a gallon into it and can hear it draining into the tank but thats it. The guy who installed it moved this weekend and isn't answering his phone. Is there something simple that he forgot to do or will I have to take it to a shop?
Thanks
May 3, 2010 at 10:03 AM
Check the down pipe where the gas goes. Make sure he didn't twist the rubber fuel line going from there to the tank. Also, there is a smaller rubber hose that goes along side the main filler tube. It is a breather. Check it to make sure it isn't blocked or damaged.
Let me know what you find.
May 28, 2010 at 8:20 AM
