1991 Ford Bronco Turned Off When Driving
1991 FORD BRONCO
250,000 MILES • V8 • 4WD • AUTOMATIC
CGDOIRON
Recently driving this Bronco when the engine suddenly turned off. I smelled distinct scent of electric/plastic burning. Smell was strongest in the driver seat. No noticible smells under the hood. Now it will crank but will not turn on. Any ideas?
Feb 23, 2010 at 11:33 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Possible ignition switch burned remove column shrouding and see if it looks burnt and melted.
Hope this helps
Thanks for donate
Feb 24, 2010 at 9:32 AM
CGDOIRON
So it turns out that it wasn't the ignition switch. Old one seemed fine but still replaced it just in case.
I did notice that the fuel pump does not kick in when the key is turned to the on position. Normally, I hear a high pitched whine from the back of the Bronco when I turn the key and before the car starts. That is not happening now even though the battery is fine and the engine does crank.
Any suggestions? Keep in mind that I am absolutely certain that the smell was electrical and inside the car when the Bronco turned off.
Mar 3, 2010 at 3:37 PM
DOCFIXIT
  • 18,828 POSTS
Check for power at Ful pump relay also check fuse links at starter trelay see if one is burnt
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_375.jpg
Mar 4, 2010 at 3:49 PM
