1991 Ford Bronco starting
1991 FORD BRONCO
159,000 MILES • V8 • 4WD • AUTOMATIC
KENF
  • 4 POSTS
got gas n battery charged.turn key tries to turn over but doesnt
Jun 4, 2009 at 9:00 AM
Have you checked fuel pump pressure and for spark?
Jun 4, 2009 at 9:40 PM
KENF
  • 4 POSTS
got fuel pump pressure but no spark off plug from ignition coil new ignition coil
Jun 4, 2009 at 9:46 PM
Are you getting power to the coil?
Jun 4, 2009 at 11:21 PM
KENF
  • 4 POSTS
the wires into the coil has power maybe brain box
Jun 5, 2009 at 6:53 AM
If you have power to the coil, I have to agree with you if you are refering to the square brain. Did the problem happen all at once or was it running then shut down for no apparent reason and restart at a later time?
Jun 5, 2009 at 11:11 AM
KENF
  • 4 POSTS
it made a noise while i was starting it and never started since.i even changed ignition switch
Jun 11, 2009 at 11:16 AM
