1991 Ford Bronco ENGINE VALVES
1991 FORD BRONCO
140,000 MILES • V8 • 4WD • AUTOMATIC
JAIME628
My 1991 ford bronco with a 5.0 motor makes noise from the engine valves (like a clicking noise) when I step in the gas to sped up. is it that my engine is losing pressure .
Dec 6, 2007 at 4:06 AM
JWALTH02
  • 180 POSTS
If it's a steady clicking coming from the valve covers, your lifters or rocker arms might be coming loose. If you do it yourself just take off the valve cover and tighten the bolts 18-25 ft lbs with a torque wrench. If that doesn't stop it let me know. Good Luck
Dec 6, 2007 at 11:46 PM
