I bought a 1991 Ford Bronco; I noticed after I bought it that it was idling high, sporadically. This problem does not happen all the time; I have fixed all the vacuum leaks that I could find. I have checked for leaks around the intake manifold. IF I goose the throttle as I am stopping at a red light the idle when stopped while in drive will drop from 1000 rpms to about 600 rpms. I replaced the IACV motor because a friend’s brother said that was what was wrong. I am now tired of guessing found someone that has an ODB1 computer to check the engine. He hooked up the computer and I think there was a code 33, then he did the KOEO test at the end of the test there were four codes 13, 44, 65, 77. He said that one or two might because I did not turn the steering wheel and press the brake in the beginning in time. I have found the codes online but have know idea what they mean and what I should try next, I am getting frustrated I love the truck but I hate this problem. Please help.
May 22, 2010 at 5:46 AM
