Wipers not working properly
1990 FORD BRONCO
JNLEMONS
  • 4 POSTS
V8 four wheel drive automatic 155,000 miles
When I turn on my wipers they are very loud and work well for about ten seconds, then they will pause in different areas of the windshield for a few seconds and the start working again then pause again. this cycle just goes on and on. I believe the motor is going bad because of the sound it is making i just want to make sure. Also, i just purchased the vehicle and it had been sitting for fourteen months. could rust in the motor or on the gears be causing this?
Sep 9, 2009 at 6:13 PM
Chances are the motor is the problem. Rust would not cause this problem. If it is making a lot of noise, then the motor is most likely bad.
Oct 23, 2009 at 1:35 PM
