1990 Ford Bronco noise in trans and wont move
1990 FORD BRONCO
114,000 MILES • 4 CYL • 2WD • MANUAL
AUCTIONGAVEL
When shifting into gear it seems fine but when you let the clutch out it sounds like the gears are not engaging all the way. Moved a little in reverse but not in foward gears. Third trans in and new clutch on second trans. Worked for a while but then this problem. Help . chuck
Feb 26, 2009 at 6:32 PM
DAVE H
  • 13,384 POSTS
hello .. thanks for the donation ..much appreciated
When was the clutch last replaced ? .. sounds like the clutch is bad or is is contaminated with oil or grease etc. and is just slipping ?
Feb 27, 2009 at 8:30 AM
