1990 Ford Bronco II - Engine
1990 FORD BRONCO
ROCKMONKEY17
  • 5 POSTS
Hi, i just bought my bronco( :D ) privatley. It's been sitting for about 2 months, just because the owner bought a more economic vehicle. And with 150,000 miles on it, im a little worried about the engine. As i said, it was sitting for about 2 months, however, on the test drive, it fired immediatley, and i let it warm up for about 4 minutes. Now, when i put it in gear, when i pushed passed about half way on the accelerator, i could a pinging noise( :? ), and i think its the lifters. It happened every gear, in that throttle range. Now im not that great with engines, but im not sure if its the throttle body, a broken engine mount and the engine is just shaking, if its the lifters, or it was still just too damn cold. I was planning on getting an engine rebuild kit anyway and doing it myself, but i just need to know if its something else( :evil: ). My friend said it was probably just cold after sitting... But, Any feedback would be GREATLY appreciated! Thanks! (2.9L V6 by the way, stock)
Jan 25, 2006 at 1:11 PM
SC1 RACING
  • 117 POSTS
i dont know what year it is but if it is an older model with a manuel fuel pump. they have been known to do that.
Jan 25, 2006 at 1:18 PM
LOVESCARS
  • 359 POSTS
If the oil hasn't been changed recently change it and put a bottle of Marvel Myster in with the motor oil see what happens???
Jan 25, 2006 at 1:22 PM
ROCKMONKEY17
  • 5 POSTS
Sorry, i should have included that in the body, its a 1990 bronco II, so i dont think its a manual fuel pump.
And i forgot he mentioned that... It is due for an oil change and a full fluid flush. Could it really be as simple as an oil change? BTW, what will the Marvel Myster do?
P.S. - Thanks for the fast responses!
Jan 25, 2006 at 1:26 PM
LOVESCARS
  • 359 POSTS
Yes it could be! I'm a firm believer to look at the obvious rather than jump to the expensive stuff right away. You should also try running a bottle of isopropyl dry gas to remove any foreign contents that may have accumulated in the old gas, with at least the recommened gallon amount in the tank. I owned a 90 ranger w/2.9 and it only liked super unleaded fuel.
If that doesn't do it I would likely recommend having the computer checked to be sure your timing is advancing with load
Jan 25, 2006 at 1:42 PM
