Transmission problem
1989 Ford Bronco V8 Four Wheel Drive Automatic 120+ miles
the vehicle would not start so i changed out the lock cylinder but then found out it did not fix the problem. i took apart the steering column down to where the lock cylinder meets with the starting lever because that is the part that was worn out. the problem is that when i put it all back together it will not shift into gear. it is stuck in park. please help only vehicle my father has. thank you.
Dec 3, 2007 at 11:23 PM
