I have been able to get fuel pressure to the engine with the pumps using a bypass on the fuel pump relay but it will not start. When I hooked up a jumper to ground off of the fuel pump test connector on the ecu connector the truck fired up and ran just fine - disconnect the grounded connection and it will die immediately. This should have it narrowed down quite a bit, but I don't know where to look from here - relays are working and fuel pumps are working - this leaves some sort of fuel control that the ecu bypasses when bypassed
Aug 25, 2009 at 4:39 PM
