1989 Ford Bronco fuel injectors
1989 FORD BRONCO
PETE409
Computer problem
1989 Ford Bronco V8 Four Wheel Drive
Engine will start one time only if I keep pumping thortle stop pumping it dies then wont start again unless you let it sit for awhile 10-20 mins.
May 25, 2010 at 3:36 PM
Check and test the ISC bypass solenoid, EGR/PCV valves and throttle position sensor/manifold absolute pressure sensor.
May 25, 2010 at 5:03 PM
