1989 Ford Bronco Engine Oil
1989 FORD BRONCO
IKESARAH1
Engine Mechanical problem
1989 Ford Bronco Four Wheel Drive Automatic
My husband thought he was gtabing the oil in the garage and grabed powerstering fluid he put it in the engine were you put the oil we drained it know what do we do the car was never started we noticed and drained it
Dec 28, 2009 at 11:05 AM
MERLIN2021
  • 17,250 POSTS
It should be fine, just refill with the right oil. Tranny fluid is sometimes used to clean the engine...just DO NOT ever make this mistake with the brake master cylinder, or you will spend MANY $$$ to fix!
Dec 28, 2009 at 2:48 PM
If you never started the vehicle and drained the oil / PS fluid out, I recommend putting fresh oil in with a new filter and run it for about 100 miles and then changing the oil and filter again. That way you are sure to have gotten all of the PS fluid out. Everything should be fine.
Let me know if you have other questions and thanks for using 2carpros.com.
Dec 28, 2009 at 2:51 PM
