1988 Ford Bronco Tire size
1988 FORD BRONCO
160,000 MILES • V8 • 4WD • AUTOMATIC
HILTSU
What was the biggest tire size (optional) for Bronco.
Mar 25, 2008 at 5:22 AM
BLACKOP555
  • 10,386 POSTS
is the truck lifted or is it stock?
is it the high stock or low stock suspension?
shocks in good brand new condition? along with leafs?
Mar 25, 2008 at 8:30 AM
HILTSU
I want know what was the biggest optional tire size (stock) from factory... I need the information, because I´m lifting my car, and the limit in Finland is 150mm (6") higher than stock...
Mar 25, 2008 at 9:22 AM
BLACKOP555
  • 10,386 POSTS
you could probably get 17 inch tires if yours come stock with 15's.
but if you put a 6 inch lift on you could be running 33's but they'd stick out past your body, you'd need fender flares or your paint would chip all up.
Mar 25, 2008 at 10:54 AM
HILTSU
I´m goint to use 4" lift kit and I am allready driving with 32 10,5 15 wheels, but I need to know, has Bronco´s ever rolled out from the factory with 33´s? If they have, I could use 35´s... Summa summarum, what was the biggest optional tire for Bronco?????
Mar 25, 2008 at 11:20 AM
