1988 Ford Bronco temperature guage sinsor
1988 FORD BRONCO
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
CAMREY
how do you replace it
Apr 9, 2009 at 12:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL:
Disconnect the negative battery cable.
Drain the cooling system into a suitable container.
Disengage the electrical connector at the temperature sender/switch.
Remove the temperature sender/switch.
INSTALLATION:
Apply pipe sealant or Teflon tape to the threads of the new sender/switch.
Install the temperature sender/switch and connect the electrical connector.
Connect the negative battery cable. Fill the cooling system.
Run the engine and check for leaks.
Thanks for using 2CarPros.com!
Apr 9, 2009 at 1:39 PM
