1988 Ford Bronco starting
1988 FORD BRONCO
BRONCO88
1988 Ford Bronco V8 Four Wheel Drive Automatic
im having problems with geting my bronco started. the fuel pumps do work but dont come on from the switch. the relays are new and if you run a wire back they work fine but im geting fuel to the fuel rail and geting fire in and out of my distributor but still wont start. if i spa gas in it it starts. if you can give me an idea where to go next i would really appreciate it. im totally confused.
Oct 1, 2009 at 6:03 PM
Are you getting power to the fuel pump relay? I realize you replaced the relay, but need to know if you are getting power to it. As far as the pump, have you checked for power to it?
Oct 23, 2009 at 11:56 AM
