About 6 months ago both my headlights go out. my truck has no relay for the headlights but I check all my underdash fuses which are all fine. I replace the the headlight switch and the harness because I found there was some damage to the harness. Nothing helped. What I ended up doing just to give my truck working lights, was I spiced into my running lights. Now the same problem has occured. Im not sure If my truck is giving to much power or if I have a bad ground (which I cant find) and advice will do
Jan 11, 2010 at 6:34 PM
