I am replacing the fuel tank and sending unit on the 1988 Bronco II and have discovered that the Snap In connection between the fuel lines and the sending unit do not match up, the plastic tabs on the sending unit side are different in shape. It appears that there was a design change in this connection, can you confirm this change and recommend an alternate solution(s) to the problem?
Thank you.
Thank you.
Jul 19, 2010 at 1:22 PM
