1988 Ford Bronco engine swap
1988 FORD BRONCO
Engine Mechanical problem
1988 Ford Bronco V8 Four Wheel Drive Automatic
I have an 1988 full size bronco with a 5.8. I need to know if a 5.8 out of a 1995 f-150 will work with my transmission and if there is anything else I need to do for this to work if it does at all.
Feb 22, 2009 at 10:34 AM
POLISHMAFIABOSS
  • 27 POSTS
It should match up and work with no problems. Get the ECM for the newer motor and use that, if at all possible. Otherwise, I don't believe there is any difference between the 88 and 95 model motors that should cause you any problems.
Mar 13, 2009 at 9:42 AM
