1988 Ford Bronco Emergency fuel shut off switch
1988 FORD BRONCO
84,395 MILES • 4 CYL • 4WD • AUTOMATIC
SETI
  • 4 POSTS
Where is this switch in a 1988 Ford Bronco I and ho do I turn in back o?
May 18, 2009 at 10:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle's inertia switch is located behind the left side of the dash, near the emergency brake mechanism.
May 19, 2009 at 12:16 AM
SETI
  • 4 POSTS
I took off the fuse cover and looked up under dashboard for about 20 minutes. I found lots of electrical connections, but no switch that I could make out. I am somewhat mechanically inclined, but I've never had so much trouble locating a switch. Just to turn my gas back on. I appreciate the help that you have given me. But if there are any other suggestions. I would appreciate it. This is for a 1988 Ford Bronco II.
Thanks for your help,
SETI
May 19, 2009 at 6:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry about that, at first you had it listed as a Bronco I ...for the Bronco II the inertia switch is located under the right side of the dash, on the firewall. I have a picture of it below.
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_26.jpg
May 19, 2009 at 12:37 PM
JESSTME63
where is the reset fuel pump button on a ford bronco 1990
Feb 4, 2019 at 6:25 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
left dide dash above brake pedal
FIXITMR
  • 9,990 POSTS
try under dash on pass side firewall near floor you may have to pull back carpet.
JOHN48
location of the inertia fuel switch
JOHN48
i have one and they do not give the exact location
TRAVIS650D
  • 8 POSTS
I read that it is located under the dash on the passenger side. i took a quick look and didn't see it.. maybe it is behind the glove box or behind the kick panel...when its a little warmer i will try to find it..and get back to you. unless you find it first...
SHAD
  • 8 POSTS
where is the fuel cut off switch? the high pressure pump is not working and need to know where the switch is.
RACEFAN966
  • 5,029 POSTS
It is under the dash just to the right (passanger) side of the transmission hump.
KHLOW2008
  • 41,814 POSTS
The inertia switch is underdash at right of transmission hump.
PINKSHELTER
Electrical problem
1988 Ford Bronco V8 Four Wheel Drive Automatic
having problems withboth fuel pumps not kicking on and the safety shut off switch not working, my switch for the key is hard to turn on also.
You need to fix the ignition switch, then test the fuel pump relay and inertia switch if both okay -Test the computer control of the fuel pump relay.
