1988 Ford Bronco dumping to much fuel
1988 FORD BRONCO
120,000 MILES • V8 • 4WD • AUTOMATIC
CAJUN_PONY
My 1988 ford bronco is dumping to much fuel @ times we change map sensor coolant & tps and check the fuel pressure sensor. No luck Please help Cajun_pony
Jan 17, 2009 at 10:10 AM
BILLYMAC
  • 2,204 POSTS
.really sounds like ecm failure.a you need to scan and check inj pulse width. the injector only stays open as long as the driver tells it too. another possibility. check the tfi module. and do a ohms test on injectors.check and see if they are equal or if resistance is more in one injector.this is a complicated prob bear with me and check these things .billymac
Jan 20, 2009 at 9:06 AM
