Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Bronco
Exterior Light
Brake Light
Not Working
Brake lights will not work all other lights work?
1988 FORD BRONCO
100,000 MILES • V8 • 4WD • AUTOMATIC
CRYSTAL52
MEMBER
1 POST
FOLLOW
brake lights will not work all other lights work new brake switch bulb is also new what else could it be other than the fuses
Jan 28, 2008 at 9:57 AM
SQM
CERTIFIED EXPERT
It sounds like you have a faulty brake light switch.
The brake light switch is what turns on the brake lights when you depress the brake pedal.
That switch is located on top of the brake pedal bracket.
You might find this information helpful:
https://youtu.be/RBCDVfzNQGk
I have attached the diagrams for your reference.
Thank you.
Aug 20, 2021 at 2:09 PM
