1987 Ford Bronco Compressor Oil
1987 FORD BRONCO
126,000 MILES • 6 CYL • 4WD • AUTOMATIC
ASIDPARA
I removed the compressor, and lost some oil through the hose connection. I could not find any fill hole. Can you help? What kind of oil should I use?
Nov 23, 2009 at 6:14 PM
COMPRESSOR MODEL and RECOMMENDED LUBRICANT
Bosch Axial.........................PAG 100
Calsonic CR14.......................PAG 46
Calsonic CWV6.......................PAG 46
Calsonic DKV........................PAG 100
Calsonic V5.........................PAG 150
Calsonic V6.........................PAG 46
Chrysler A590.......................PAG 46
Chrysler C171.......................PAG 46
Chrysler RV2........................PAG 100
Denso 10P...........................PAG 46
Denso 10S...........................PAG 46
Denso 2C............................PAG 100
Denso 6C............................PAG 46
Denso 6CA...........................PAG 46
Denso 6E............................PAG 46
Denso 6P............................PAG 46
Denso 6SB...........................PAG 46
Denso 7SB...........................PAG 46
Denso SC08..........................PAG 46
Denso TV............................PAG 100
Ford FS10...........................PAG 46
Ford FS6............................PAG 46
Ford VF2............................PAG 46
GM A6...............................PAG 150
GM HR/HT............................PAG 150
GM R4...............................PAG 150
GM V5...............................PAG 150
GM V7...............................PAG 150
Hadsys HS-090L......................PAG 46
Hadsys RC17.........................PAG 46
Hitachi (all models)................PAG 46
Keihin (all models).................PAG 100
Matsushita (all models).............PAG 46
Mitsubishi (all models).............PAG 46
Nihon DKV...........................PAG 100
Nihon NVR...........................PAG 100
Panasonic (all models)..............PAG 46
Sanden Electric.....................SE-10Y
Sanden SD5..........................PAG 100
Sanden SD7 (key shaft)..............PAG 100
Sanden SD7 (splined shaft)..........PAG 46
Sanden SD7V.........................PAG 46
Sanden TR...........................PAG 46
Sanden TRF..........................PAG 46
Sanden TRS..........................PAG 46
Seiko-Seiki (all models)............PAG 100
Tecumseh (all models)...............PAG 100
York (all models)...................PAG 100
Zexel DCV...........................PAG 100
Zexel DCW...........................PAG 46
Zexel DKP...........................PAG 100
Zexel DKS...........................PAG 46
Zexel DKV...........................PAG 100
Zexel TM............................PAG 46
Nov 24, 2009 at 3:44 AM
You have to run it thru the AC Recover, Recycle, Evacuate and Recharge Machine
Nov 24, 2009 at 10:34 AM
