1986 Ford Bronco oil pressure drops
1986 FORD BRONCO
Engine Mechanical problem
1986 Ford Bronco V8 Four Wheel Drive Automatic
why does oil pressure drop all the way down after running for about half an hour?
Apr 18, 2008 at 11:39 PM
You need to check the oil pressure with a mechanical gauge-if normal replace the oil pressure switch-not normal could be the oil pump or excessive engine bearings clearances-
Apr 19, 2008 at 8:10 AM
