This bronco sat for about 2 years. I have drained old fuel, replaced the fuel pump in the tank, the high pressure fuel pump, fuel pressure regulator, fuel injectors, spark plugs, air charge sensor, MAP sensor, and clean EGR valve and entry in to the intake manifold, put clean fuel into the tank after cleaning the tank also. the vehicle now starts, i am able to rev the engine after a cold start, but when the engine warms up and i press the gas pedal it kills the engine, almost as if it is getting flooded. I believe it is temperature related because after it dies i have to wait for it to cool off before attempting to start it again. i
May 28, 2007 at 9:32 PM
