Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Bronco
Climate Control
Heater
Not Working
1986 Ford Bronco Heater and overheating issues
1986 FORD BRONCO
60,000 MILES • V8 • 4WD • AUTOMATIC
BROKENBRONCO
MEMBER
1 POST
FOLLOW
The engine runs hot, but the heater blows cold. I've replaced the thermostat, and flushed the radiator. Could it be a wiring issue?
Jan 21, 2009 at 10:42 AM
CERTIFIED EXPERT
Hi:
It sounds like the radiator is still plugged. You may want to consider having it rodded out. Sometimes spraying water through it isn't enough.
As far as the heat, are both heater core hoses getting hot when the engine is hot, running and the heat is on?
Jan 22, 2009 at 8:36 PM
