1986 Ford Bronco Driver Side Window Motor Replacement
1986 FORD BRONCO
60,000 MILES • 6 CYL • 4WD • AUTOMATIC
GEARJMRROB
MEMBER
1 POST
FOLLOW
I removed the driver door inside cover, but how do I remove the electric window motor???
Jan 2, 2008 at 10:50 AM
F.FREEMAN
MEMBER
1 POST
having just gone through this lovely problem with my 88 bronco. you find the 3 dimples in the metal door panel metal and drill them out. the dimples were put there by for to be drilled out later. behind them are the 3-10mm screws that release the motor
