1984 Ford Bronco trouble shooting
1984 FORD BRONCO
175,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARK B JOHNSON
my bronco II sat for about 6 years now the transmission wont go into gear forward or reverse it worked fine before what should i do
Feb 17, 2009 at 8:47 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
This sounds as if it has lock up a shift valve due to sitting around for so long, you can try just allowing the oil to circulate and warm up and attempt to select gears, but i feel it will be a job for a transmission specialist to remove the valve body and inspect for frozen valves.
mark (mhpautos)
Feb 18, 2009 at 1:55 AM
