Im am currently work out a few bugs on my 84 bronco. Used to run fine then it wouldnt start or turn over but could push start it. I took to a mechanic said the new starter i had just put on was burned out and the solenoid as well. he said he replace about 4 solenoids on it. when crank the solenoid remain engaged but with a light tap it stops and will run. however the last time it wouldnt stop and i pull the key out and it kept running and died right there. Any ideas on what to do?
Jul 21, 2010 at 10:47 AM
