[quote:864d7169be="racefan966"]Ok even if you get spark keep in mind this sat 7 yrs there is going to so many fuel problems that you will doing a fuel filter and probably droping the tank and cleaning and such. The fuel is going to be bad and thick. There is usually 2 fuel filters on this too. One in a black canister near the rear and one inline filter near the front on the frame.
Now back to the start problem with the distributor cap off does the rotor turn? Do you have voltage to the possitive side of the coil and how much? Do you have power to the neg side of the coil and how much? Get back to me this and we will see where to go with it next ok.[/quote:864d7169be]
Alright back, This is what has happened so far fuel lines were clogged up but i noticed that the throttle pedal was stuck so i took the whole carburetor apart to get the throttle unseized ended up doing a whole rebuild on it in the process i have taken the whole tank off and have been cleaning it and unclogged all the lines but since i got the carburetor back together and on the truck i have put gas in the bowl and have tried to get it to start only way i could do this was by jumping it because the battery kept draining after i charged it but anyways it turns over really fast
wait before i hooked the jumpers up to it when i would try to start it with the battery only it would not fire until the battery was just about drained then it seemed like it would almost start or at least try too so then that was when we hooked the jumpers up and it seemed like it wasn't getting any spark so my father got his spark tester which when we watched it seemed like it would get spark right as i turned the ignition and right when it would slow down so now i need to know what could cause this.
and by the way i know it was getting fuel because my dad was constantly spraying fuel and starting fluid into it every time we would try to start it.
Dec 14, 2008 at 7:13 PM
