1984 Ford Bronco Ignition
1984 FORD BRONCO
99,000 MILES • V8 • 4WD • AUTOMATIC
RICKYR
The engine runs when I put a jumper wire from hot side of battery to hot side of coil. Will not shut off until I remove jumper wire. This is the only way I can get it to crank.
Jun 13, 2010 at 11:11 AM
BLACKOP555
  • 10,386 POSTS
your going to have to check the wire from hot side of the coil back to ignition switch. if thats all good. the ignition switch may have failed.
Jun 14, 2010 at 11:27 AM
