1984 Ford Bronco Heater Core
1984 FORD BRONCO
127,000 MILES • V8 • 4WD • AUTOMATIC
BRYANPEARSON
Can you provide a step-by-step procedure with pictures for changing the heater core? Vehicle has air conditioning.
Nov 10, 2010 at 9:07 PM
BLUELIGHTNIN6
  • 16,542 POSTS
1980-86 With Air Conditioning Do not discharge the air conditioning system. Disconnect the heater hoses from the heater core tubes and plug the hoses with suitable 5 / 8 inch; (16mm) plugs. Remove the glove compartment liner. Remove eight (8) screws attaching the heater core cover to the plenum and remove the cover. Remove the heater core from the plenum taking care not to spill coolant from the core.
https://www.2carpros.com/forum/automotive_pictures/261618_1_208.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_2_134.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_3_59.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_4_25.jpg
To install: Install the heater core in the plenum. Install the heater core cover (eight screws). Install the glove compartment liner. Connect the heater hoses to the heater core. Tighten the hose clamps. Add coolant to raise the coolant level to specification.
Nov 11, 2010 at 1:41 AM
