1983 Ford Bronco Fuel pump
1983 FORD BRONCO
LILKOZUR
Engine Mechanical problem
1983 Ford Bronco 6 cyl Four Wheel Drive Automatic
I have A 83 ford bronco with a inline 6. i unbolted the fuse box in the the cab to run wires for off road lights and before i put it back i messed with the fuses and put it back the truck didn't start. I know it's not getting fuel and i the fuel pump is not coming on i can usually hear it for a second. none of the fuses are blow. How can i get it running??
Sep 10, 2008 at 6:59 AM
CWHIT114
  • 8 POSTS
check the fuel pump relay, it has been known to stick, try replacing it or giving it a good tap
Sep 29, 2008 at 8:52 AM
