1979 Ford Bronco Engine will not go over 2500 rpms
1979 FORD BRONCO
80,000 MILES • V8 • 4WD • MANUAL
MJHEAD13
It has a 351m,it has ran perfect then all of a sudden it would not go over 2500 rpms,if i try to push it any harder it backfires,it starts fine idles fine and anything under 2500 rpms you would not know any thing was wrong with it got any thing to try.
Mar 16, 2009 at 2:55 PM
MERLIN2021
  • 17,250 POSTS
Try a new distributor vacuum advance...
Mar 16, 2009 at 2:59 PM
MJHEAD13
is ther a way to tell if the vacuum advance is bad
Mar 16, 2009 at 5:14 PM
MERLIN2021
  • 17,250 POSTS
Use a vacuum pump apply vac, if it leaks or does not pump up, its no good, also remove the distributor cap, and see if the plate moves, it could be frozen in place.
Mar 17, 2009 at 1:15 PM
