1969 Ford Bronco blinkers/speedo
1969 FORD BRONCO
125,000 MILES • V8 • 4WD • MANUAL
TITANZRM
I have a 1996 ford Bronco the blinkers quit working but the emergency flashers still work, also the speedo quit working when the blinkers went out, the heater and the just quit working later. I checked all the fuses inside and under the hood all are fine, I repalced the flasher in both the front and back of the fuse panel. The truck still starts and runs fine both the headlights and taillights still work fine.
Oct 15, 2010 at 10:16 AM
Are you getting power to the flashers? As far as the speedo, is the trans still shifting correctly?
Oct 15, 2010 at 10:13 PM
