Ford Aspire
FORD ASPIRE
ROBSIE
  • 4 POSTS
Car cuts out when you accelerate. I have changed plugs, plug wires, cap, rotor, and fuel filter. It still cuts out. Please help.
Jul 8, 2007 at 12:15 AM
JWALTH02
  • 180 POSTS
What do you mean by cuts out? Does it die completely? Does it not accellerate at all? Need to know a little more about the problem.
Jul 8, 2007 at 3:36 AM
ROBSIE
  • 4 POSTS
It idels fine but when I accelerate it starts cutting out but it dosen't die. It acts like its starving for gas.
Jul 8, 2007 at 4:30 AM
JWALTH02
  • 180 POSTS
Ok first I would go for your fuel filter. It's probably pretty old and it's a cheap solution. You're probably gonna need specialty tools to disconnect the fuel lines but I'd ask just to be sure when you go to pick it up. Try that and let us know.
Jul 8, 2007 at 1:11 PM
ROBSIE
  • 4 POSTS
I changed fuel filter didn't help.
Jul 9, 2007 at 2:23 AM
THIS IS MIKE
  • 686 POSTS
It sounds like your fuel pump could also be failing, if you haven't already replaced it, that could be your next step.
Jul 10, 2007 at 11:17 AM
ROBSIE
  • 4 POSTS
I don't think it's the fuel pump. It seems to be getting enough gas. Could it be the catalytic converter is stoped up?
Jul 15, 2007 at 6:11 AM
LOOPIE
have you fixed this problem??? i have a 96 and it is doing the same thing... i believe it is the ECM...Advanced Auto Parts can check to see if it is good or bad.
Sep 14, 2008 at 5:33 PM
PCMENTOR29
  • 177 POSTS
I am sure it's clogged fuel injectors. But need to test my theory as yet. I will let you know when I replace them.
Jul 13, 2009 at 12:01 PM
