1996 Ford Aspire squeeling noise when starting
1996 FORD ASPIRE
110,000 MILES • 4 CYL • FWD • MANUAL
RUTHANN57
Hi, most everytime I start the car it squeels pretty loud and then sounds like a screech (scrape maybe) wondering what is causing this. I usually start with car in gear with foot on clutch and emergency break on. Thank you
Oct 7, 2010 at 10:20 AM
Check the alt belt to make sure it is tight and in good condition. Let me know what you find.
Oct 15, 2010 at 10:04 PM
RUTHANN57
Joe, turns out mechanic told me it was the water pump going.
Nov 5, 2010 at 6:47 PM
It was most likely getting coolant on the belt causing the noise. I'm glad you found the problem. Let us know if you have questions in the future.
Nov 6, 2010 at 1:47 AM
