1996 Ford Aspire How do I test the flow of an fuel injector
1996 FORD ASPIRE
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
PCMENTOR29
  • 177 POSTS
How do I test the flow of an fuel injector off car? I am getting a P0300 Random Misfire, with high HC and high NOx. Replaced all ignition components and tested coil spark. MAF tests per spec, as well as TPS. I plan to hold attached fuel rail with injectors attached and fuel pump running over a small bucket and observing the spray pattern of each injector as I energize each with 12 volts. Does it matter which way the 12 volt wires are connected? I am looking for a conical spray pattern, right?
Jul 13, 2009 at 11:57 AM
PCMENTOR29
  • 177 POSTS
This P0300 turned out to be the ignition timing. Using the mark to time it gave wrong timing so used ear, set until pinging then retard a little just to stop ping worked great. Good power and smog.
Dec 9, 2012 at 6:05 AM
