1994 Ford Aspire Rusty foam in radiator
1994 FORD ASPIRE
187,000 MILES • 6 CYL • FWD • MANUAL
RDSQUID
My radiator and overflow reserve are filled with an orange foam.
Several people have said this means oil from head gasket but there is no oil smell, sheen, or feel.
I also have driven several thousand miles with it like this.
What is it and should I stop driving until repaired?
Mar 14, 2010 at 10:52 PM
2CARPRO JACK
  • 11,533 POSTS
Does it look like rusty water perhaps.Normally this could mean that the trans cooler was leaking into the radiator, but since you have a mnaual trans, that isnt likely.Oil level is good? not mysteriously using oil? Did this just happen all of the sudden? If not haev the coolling system pressure flushed and the coolant replaced with fresh.Then monitor it to see if anything changes.Some coolants (Dexcool) ar orange in color, so it may not necessaarily look green like you may think it will after being flushed and filled
Mar 15, 2010 at 7:57 AM
