1994 Ford Aspire Keeps blowing the engine Fuse
1994 FORD ASPIRE
BRANDON REID
Engine Mechanical problem
1994 Ford Aspire 4 cyl Automatic
Hi
I have a 1994 Ford Aspire
The car stalled and would not restart.I found a 10 amp fuse blown i replaced the fuse the car ran for a few seconds and stalled again >I checked the fuse and had blown again I replaced it again with the same result could i have a bad fuel pump
Thank you
Brandon
Oct 13, 2008 at 11:47 PM
SBARNE3
Brandon,
Did you ever figure out what it was? I am looking to buy a 96' Aspire that has this problem, but if it is something major, I will probably pass on it.
thanks,
Steven
May 13, 2009 at 3:01 PM
NICK MCKNIGHT
this is old, but i need to bring this to light... i replaced the 10a fuse with a 15a and it blew... put a 20 in and its running... i have been told its because the fuel pump is going out. it requires more current to run because of the pump going out, which is causing the fuse to blow. i drive very little, but we left the car run for a half hour while sitting and checked for burns and smells (under the dash and in the bay) but found nothing wrong. i can say there havent been any problems after about 30 miles... the fuel pump is requiring more current to do its job. i have been told 9/10 times its the fuel pump... i dont condone running with a higher fuse, that is my personal choice.
Sep 4, 2016 at 8:19 PM
