Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Aerostar
Climate Control
Defroster
A/C blows out defroster
FORD AEROSTAR
291,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALANDDAVIS
MEMBER
FOLLOW
My A/C is blowing out the defroster vents, not the dashboard vents. Help!
Aug 16, 2008 at 2:10 PM
KHLOW2008
CERTIFIED EXPERT
Hi alanddavis,
You need to check the vent linkages and adjustment. Is the control adjusted to the correct position?
Aug 16, 2008 at 10:20 PM
ALANDDAVIS
MEMBER
I'm pretty sure the linkage is okay, but I'll try to check it. Thanks.
Aug 18, 2008 at 11:57 AM
CERTIFIED EXPERT
check the vacuum source tube, it is probably broken causing the vent to stay in the defrost position.
Sep 16, 2008 at 5:18 PM
ALANDDAVIS
MEMBER
Thanks. I found a little critter had made a home in the blower motor. I pulled out a nest and had to repair the vacuum hose. It's working fine now.
Sep 16, 2008 at 6:10 PM
