1996 Ford Aerostar Transmission is leaking from pan gasket
1996 FORD AEROSTAR
TEMEPST2
Transmission problem
1996 Ford Aerostar 6 cyl Automatic 95774 miles
My transmission is leaking from the pan gasket.
What can I do to fix this? How do I fix this? Does this indicate other problems with the car?
Thanks
Jun 28, 2008 at 10:46 PM
LEGITIMATE007
  • 5,121 POSTS
no it just means your gasket is shot, a tranny service at the shop will replace that, the filter and new fluid, but you can do it yourself, just make sure you get something big enough to hold about 10quarts for the fluid. and get the correct amount of fluid for your vehicle
Jun 28, 2008 at 10:53 PM
