Replacing the power steering pump can be done by following few steps.
First you want to make sure the leak is from the pump and not from the hose that goes into the pump.
Drain fluid from pump reservoir, then disconnect pressure and return lines at pump.
Take off drive belt.
Remove power steering support brace.
Remove the pump.
You will need to use a special tool to take the pulley off of the pump. Which you can rent from your local auto parts store.
You might find these articles helpful:
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
https://www.2carpros.com/articles/remove-reinstall-power-steering-pulley
Thank you.
Aug 27, 2021 at 11:52 AM
