1996 Ford Aerostar idle up and down
1996 FORD AEROSTAR
TAMMY HOWARD
Engine Performance problem
1996 Ford Aerostar
My aeroster was leaking from the heater hoses, I fixed them yesterday, no more leak and the air and heat are working much better. I have a new problem today, which is the idle is up and down and it is stalling out. If I am driving over 20 mph she runs well, if I slow down to turn or stop at a light, she stalls out, not every time, but most of the time. Could it be a vaccuum leak? Thanks, Tammy
May 7, 2008 at 8:08 AM
MUSTANG87
  • 261 POSTS
check around the throtle body all air vaccume hoses for cuts to soft mushy or disconectet line.if all ok you will most likely need a new IDLE AIR CONTROL VALVE.you find this part on the throtle body u cant miss it.looks like a 3 inch cylinder with a black plastik connection tip.u can see this part also in here www.kragen.com can be a bit pricy from 50 bucks to 130 bucks. or u can go toi a junk yard and look for the part used if u wanna save money.good luck
May 7, 2008 at 3:37 PM
