1996 Ford Aerostar Changing Fuses
1996 FORD AEROSTAR
12,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKARONI
My brake lights are out. I want to try to change the fuse, inside the car as well as under the hood. How do I do this? How do I know which is the brake fuse? Thanks.
Sep 12, 2009 at 5:18 PM
DONALDGOLDSR
  • 38 POSTS
[quote:5e04905b8e="mikaroni"]Brakes problem
1996 Ford Aerostar 6 cyl Four Wheel Drive Automatic 120,00 miles
My brake lights are out. I want to try to change the fuse, inside the car as well as under the hood. How do I do this? How do I know which is the brake fuse? Thanks.[/quote:5e04905b8e]
If all brake lights went out at once, I'd check the brake light switch mounted to the upper brake pedal bar.
Sep 14, 2009 at 8:20 PM
