COMPONENT LOCATIONS
Control Module --------------Ã Behind Lower Center Of Instrument Panel, Below Ashtray
Diode/Resistor----------------Ã Behind Left Side Of Instrument Panel, Taped To Harness
RABS Test Connector-------Ã Behind Left Side Of Instrument Panel, Taped To Main Harness
Speed Sensor -----Ã Threaded Into Front Of Differential Housing
RABS Valve Assembly ----------------Ã On Left Frame Rail, Toward Rear Of Engine Compartment
RETRIEVING TROUBLE CODES
Ensure ignition switch is in RUN position (engine does not need to be running). Locate Black RABS test connector. Connector has 2 mating halves. One has a Black/Orange wire; other has a Red wire. Disconnect connector. Connect jumper wire to connector terminal with Black/Orange wire. Ground other end of jumper wire for 2 seconds. When ground circuit is completed then broken, Yellow REAR ANTI-LOCK warning light will flash trouble code.
Code will repeat until ignition is turned off. Code consists of a number of short flashes followed by one long flash. Count each flash, short and long, to determine code number. For example: short, short, long, is Code 3. Perform corresponding code test after retrieving code. A Code 16 indicates system is operating properly
Mar 14, 2009 at 6:02 PM
