1995 Ford Aerostar Transmission linkage
1995 FORD AEROSTAR
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
THEMOODYSTWO
I took out my dads transmission and replaced the front transmission seal and put it back in. I filled it with trans fluid and started it up and run the gears thru low, second and drive and overdrive. I then put it back in park and than back in drive to move forward and I got nothing in all the gears. I also check the dip stick and it was showing past full which I know it shouldnt be so I look underneath to see that I hooked up the linkage right. It has to linkages close together. I had my dad move the gear shift and only one in moving and the second one is just staying there could that be my problem. Thanks
Jul 27, 2010 at 10:43 PM
Only one should move. I believe the other you see is the kick down linkage. Are you sure the linkage is putting the shifter in the correct position?
Aug 13, 2010 at 10:20 PM
