1995 Ford Aerostar Car will not start
1995 FORD AEROSTAR
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
TALES
When we try to start the van, the starter works and the engine cranks, but will not start. Tried replacing fuel filter (in line). Sometimes it does start after repeated attempts, but has trouble starting cold. After running the van for part of the day, we can get it to start w/o problems if the engine is still warm.
Jan 11, 2009 at 5:09 PM
Check the fuel pressure and get back with it we move from here.
Jan 11, 2009 at 5:20 PM
TALES
How do I check that? The link on your question shows a connot find page error message...
Jan 11, 2009 at 5:25 PM
I strongly recommend you seek professional help this one can be complicated.
Jan 11, 2009 at 5:30 PM
TALES
I may have to- but I may also just try replacing the fuel regulator... It looks like it may not be to hard.
Jan 11, 2009 at 5:38 PM
Okay get a fuel pressure tester and check the pressure the only way to nail the pressure regulator-remove the vacuum hose on the regulator do you have fuel on it? if so its gone-if not test the coolant temperature sensor.
Jan 11, 2009 at 6:18 PM
