1993 Ford Aerostar will not start
1993 FORD AEROSTAR
BRENDAJEAN1961
Engine Performance problem
1993 Ford Aerostar Front Wheel Drive Automatic 90000 miles
the van will trun over but will not start it is getting gas and power we already replaced the distributer cap. and checked the plug and it has plenty of gas and oil. and it is getting fuel and we have check the relay switch.
Sep 17, 2010 at 5:03 PM
Do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sep 18, 2010 at 12:19 AM
