Hi there mortuarium and TY for the donation this is what keeps the site going.
When you remove the filter did anything fell off from the valve body and did you tightened the filter properly. Is it in the correct fluid level when tranny comes up to normal operating temperature If so did you use the correct type fluid-see info below
TSB 06-14-4
07/24/06
MERCON ATF IS BEING REPLACED BY MERCON V
ATF AS A SERVICE FLUID.
1986-1996 Aerostar
Oct 4, 2009 at 8:47 PM
