1993 Ford Aerostar Misfire
1993 FORD AEROSTAR
209,000 MILES • 6 CYL • 2WD • AUTOMATIC
IBMTECH
My 93 Aerostar will run fine when cold once it has warmed up it will skip on 1 cyl when you restart it. If you let cool it will start and run fine. The engine does not use oil, no smoke, no odd noises from the engine. I have done a complete tune up (wires, plugs, cap, rotor, ect) I have no check engine lights, no codes what so ever. I done a compression check all cyl have 140-145.
I'm leaning towards a fuel injector shutting down what do you think?
Nov 10, 2008 at 8:43 PM
It could be a fuel inj. problem. Because there are no codes, we don't know what cylender is missing. I'm leaning to a weak coil.
Nov 27, 2008 at 10:54 PM
IBMTECH
[quote:92cb9ea167="Jacobandnickolas"]It could be a fuel inj. problem. Because there are no codes, we don't know what cylender is missing. I'm leaning to a weak coil.
Joe[/quote:92cb9ea167]
It skips on 2 cylinders 1 & 2 both on the right side. The coil has been replaced along with the Dist and module. I can get both cylinders firing on the highway with a steady throttle. I have checked the cam with a dial indicator and its well within spec's. I just ran injector cleaner and that helped. So I'm going to replace the injectors and hope for the best unless someone can enlighten me to another possible cause..
Nov 28, 2008 at 12:52 PM
Hi:
If the compression is good and ignition is firing properly, that is the last choice. Let me know what you find.
Nov 28, 2008 at 2:53 PM
IBMTECH
[quote:d9b3feca15="Jacobandnickolas"]Hi:
Joe[/quote:d9b3feca15]
Hi, I installed the new injectors and it runs great now looking at the injectors from the right bank two were caked with carbon like deposits one the tip was damaged I don't know how this happen it's the first time they have been removed. Thank you for your time!
Nov 29, 2008 at 3:32 PM
